tacogarage
I think the new tacos look really good all around, the air dam would come off immediately though, what else would you change?
These right? Great choice!I really wanna find a set of Tundra TRD pro BBS wheels to put on my TRD Off-road.
Yep! I just hope that the lug pattern matches up.These right? Great choice!
Lug pattern will be the same. I’m not sure about offset though.Yep! I just hope that the lug pattern matches up.
I think the tailgate will is locked from the factory this time around. The bed also has the same channels as current gens so tonneau covers will be available very quick im assuming.I really like mods I did to my 23 Tundra and will do the same for the Tacoma. First things to do is to put a cat shield on, glass screen protector, custom floor mats, tailgate lock, rolling hard bed cove, and bed rug liner.
mine locks as well. However the thieves bust the window and hit the unlock button. The tailgates are very expensive now with all the electronics. Adding the Mcguard prevents that.I think the tailgate will is locked from the factory this time around. The bed also has the same channels as current gens so tonneau covers will be available very quick im assuming.
I’m a big fan of these stickersFirst mod is eliminate air dam...
Second mod, get rid of OEM tires and get KO2 or KO3, preferred 265/70 on R18's from factory 265/65 R18...
Third, new air filter, TRD or K & N...
Fourth, new front skid plate setup to replace factory stuff on TRD Sport...
Fifth, place 'Happiness is not Automatic' decal with gear pattern on back window because I have a 6-speed manual coming...
That’s exactly what I want to do with my offroadIf I can find a Trailhunter the only things I would do is rip that stupid bar thing out of the bed and put in a tri-fold tonneau.
If I end up with an OR I would swap out the grille for the Pro grille and put on the white/amber Rigid fog lights. And add the tonneau. MAYBE some wheels like the ones above. Sadly, taking a iForce Max OR and doing these things would end up costing the same as a Trailhunter.
I was worried about this too but the engineer said the cat is up in the engine compartment now and very hard to get to, so no shield needed it seems.I...First things to do is to put a cat shield on, ...
