IAmGroot
Colby
San Francisco
‘24 TRD OR Bronze Oxide
Just installed these 295/70R17 (33.3”) on 17” Method 314 (+25 offset) on my TRD OR with stock suspension and there’s no rubbing! I haven’t fully flexed everything out, but it all looks like it’ll fit when stuffed. Also didn’t have any rubbing when turning into my driveway at full lock. I’ll be updating once I get it on some ramps in this post and on my IG below.
IG: @taco_2187
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! IMG_0266
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! IMG_0265
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! IMG_0263
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! IMG_0264
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! img_0358-jpe
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! img_0359-jpe
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! img_0360-jpe
Powhunter
Alberta
That looks really good. I was actually contemplating this size as well with that same offset. I do plan on off-roading and that looks really close to the fender wells. Might be better with a level?
drabon74
DR
Aynor, SC
2021 4-Runner
To me, the +25 offset is the sweet spot. I like the wider stance but not a fan of a lot of poke. Your truck looks great!
IAmGroot
IAmGroot
Colby
San Francisco
It’d likely be better, yes
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! IMG_0282
2024 Tacoma TRD Off-Road stock suspension with 295/70R17 (33.3”) on 17” Method 314 (+25 offset), No rubbing! IMG_0272
, but I just put an 8” ramp on both the front driver and rear passenger sides of the truck, getting it pretty decently stuffed, and I still couldn’t see any spots where it was/would rub. Maybe at that kind of stuff if you turned too much in one direction you’d touch some of the liner, but that’s really all I can see happening with this setup.
IAmGroot
IAmGroot
Colby
San Francisco
Thanks dude! I agree, +25 is the perfect amount of poke.
Taco Azul
MP
Portland
Tacoma Trailhunter LB, Tesla Model X, Polestar 2, Toyota GR86
Raised white letters are the chef’s kiss
apryakhin
Art
CA
@IAmGroot Do you think 285/70/R17 tires would also work with this method wheels? I am all over the forum and trying to decide what wheels to go for. Mine is same color as yours but TRD Sport. It does seem that I am not that far away. I am based off Santa Cruz.
apryakhin
Art
CA
Maybe I should just get the same wheels/tires. What width are your method 314 rims?
IAmGroot
IAmGroot
Colby
San Francisco
Looking good Colby!
Howdie neighbor! Yeah I think those would work considering mine are larger and they fit.
Muckle
NA
Have you been able to do a full suspension cycle and see if there is any rubbing? I'm looking at this setup in a KO3 with stock suspension, plus possibly a leveling kit. Would prefer the 295 over 285, but only if there is no rubbing.
robfultz
Rob
2024 Tacoma Off Road
IG: @taco_2187
How much poke? Or same as stock with your +25 offset?
I want a little poke but not extreme.
Fiigtaco
24 TRD OR
Looks good!
what do you do for TPMS sensors? Did you have to get your own or does the tire ship have them and just clone the stock wheels?
