Has anyone else noticed a weird intermittent rpm bump of about 100-150rpm when stopped in drive? It happens every 45s or so. I have no accessories on.
If its doing it in 6MT then its not transmission related, assuming that you are in neutral when at the stop light. I wonder if this is part of ecu learning and adjusting the maps to suit our driving style.I think it may be the same thing I noticed the other day, if so I'm glad I'm not alone and I hope it's oddly normal. I couldn't tell if it was a spike or a drop but the gauge don't really move or hardly moves, but you can feel it and hear it with the music off. It'll also vibrate the shifter in my 6M. Tried to video it but you can't really see it on the video.
None of the accessories were on. The electric fan kicks in 5-10s after the surge, therefore i doubt its the fan.A/C compressor cycling? Or electric fan cycling?? Wierd.
Only time I've noticed it was when I was idle minded while idling the truck in neutral with parking brake on. I'll have to pay more attention to see if it's an all the time thing or an occasional thing.If its doing it in 6MT then its not transmission related, assuming that you are in neutral when at the stop light. I wonder if this is part of ecu learning and adjusting the maps to suit our driving style.
My electric fan cycles even when I turn off the ac. Just running the vents. AnnoyingA/C compressor cycling? Or electric fan cycling?? Wierd.
The jolt has happened to me like 3 times when slowing down for a stopHas anyone experience a jolt in transmission when decelerating to a stop? This only happened once but i worry it may be related to my initial post about rpm spikes at a stop.
I noticed this the other day! I'm like man my AC is off but it's still really cold air.A quick update on this topic. So the weird RPM surge was due to AC constantly kicking in. What i realized was that there is bug in the software where even if the AC is OFF and you run the climate on windshield / foot mode it will kick on AC (yes even if your display is showing AC OFF). By switching the climate to forward facing and cycling AC ON OFF is the only way i was able to complete shut off AC.
If you are in AUTO mode the AC will always be ON unless you switch it off by going to Vehicle / Settings / Climate.
I noticed when I remote start the vehicle the AC is running and yet the indicator light is not on at the switch. When I turn it on and back off then it kicks off the AC. I think that'll help you.I noticed this the other day! I'm like man my AC is off but it's still really cold air.
