Duck Amuck
I installed my Bison tonneau a few days ago, and today finally had some time to make some adjustments and take some photos of the finished product. Overall, I am very happy with the product for the price. At $720 CAD delivered, I think it's amazing value and can overlook some of the minor niggles I have with it. It looks great and feels incredibly solid. Bison says it can handle 350 lbs of weight - I'm 180 lbs and stood on it with no issues (you can see my dusty shoe prints in some of the photos). We haven't had any rain and I didn't think to spray it with the hose to see how waterproof it is, but I guess we'll find out.
First, some pictures:
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9267
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9269
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9264
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9265
My negatives are mostly related to installation and quality control. The included instructions are next to useless. I wound up finding a YouTube video of a guy installing one on his third-gen, and that was very helpful as installation is basically the same. The biggest issue is that they don't tell you that you need to remove the factory tie-down rails as the tonneau rails use the same bolt holes. The factory rails then get relocated onto the brackets that come with the cover. Once you figure this out the install is pretty intuitive and goes very quickly, except for one quibble I'll address below.
This leads me to my first big negative, which is that by repositioning the tie down rail, you block access to the in-bed 12V power. Today I removed the rail and took the door off the power port, which solved the problem. I just kind of set the door in its place and visually it looks normal, we'll see if it jostles loose on dirt roads. I read a post on here from someone installing a different product with a similar issue, they were recommended to use little magnets to keep the door in place, so I may try that if it becomes an issue later on.
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9261
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9263
Although a minor issue, it would have been really nice to know because getting the factory tie down rails back on was for me the hardest part of this install. It's hard to describe, but the bolt is very short and the head is shallow, so I couldn't get it started with a socket, and because it's inside the factory rail, I couldn't get another tool in there. I had to very gently get it started by hand before I could finish it up with a socket. This was tedious and took a lot longer than it should have - if they'd used a screw with a Torx head (or literally any head) this would have been a LOT easier.
Finally, the bars that hold the cover in place when folded up were not located properly and were not usable. I had to unscrew the brackets and shuffle them a bit further back, and now they're fine. Literally a two minute fix and not the end of the world, but a little annoying.
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9266
2024 Tacoma Bison Tonneau Cover Install and Review Impressions IMG_9270
Overall, I have to say I am very happy with this cover. It looks great, it seems well-made and secure, it locks, and of course it can be used in a variety of positions. Considering it's by far the cheapest hard cover I've seen, I can deal with a couple small inconveniences and poor instructions.
Sner
having to move (lower) the factory bed rails to mount hard tonneau cover is a deal breaker for me. I have the OE bed divider that slides on the OE rails, if the rails were lowered I wouldn’t be able to use my bed divider. The OE soft tonneau cover has solved that problem for me, the drawback to it is you can‘t flip the third panel up against the rear window To give you full bed space. If you want full bed space you need to remove the whole cover.
Halifax, NS
2025 TRD Pro
Wait, regarding the relocation of the rail, and the power outlit, does this also happen on the mx4/oem hard tonneau ??
In regards to lowering the rails:
OEM - Yes, they are lowered. But I can access the power outlet as normal.
MX4 - IIRC they updated to where you don't have to lower them.
Goriders
2024 Tacoma Sport Plus
Looks a lot like the OEM tonneau which is a bakflip MX4
i have the cargo divider as well. I managed to get it in but had to trim the ends a bit and it probably won’t work with a bed mat. It also runs into the arms that hold the tonneau up.
i just used it as a toolbox so it works for what I needed.
Duck Amuck
Duck Amuck
Looks nice but blocks the review cam.
We don't get the rearview camera in Canada, so no real loss.
The cover can be used in 2/3 mode if the load doesn't fill the entire bed, which would leave the camera uncovered.
TacoEater
Daniel
Ottawa
POS Nissan Pathfinder, soon to receive 2025 Tacoma
This is an absolutely amazing post and thank you! I live not too far from the Whitby plant so I may make the drive and take advantage of the “free install” option. Quick question; do you think that the OEM rails are now less secure or can handle less of a load, seeing as they are now screwed into the smaller aluminum brackets provided by Bison vs. being screwed into side of the bed ? Maybe I’m overthinking this but I do plan on using those rail tie-downs quite a bit, and to secure a fairly heavy kayak. So I can envision a lot of tension being put on the “relocated” rails.
Any advice helps, I pick up my new TRD OR in a couple weeks and can’t wait!!!
Duck Amuck
Duck Amuck
Hey thanks! Six months in and I'm still very happy with the cover. It does let in some water and snow, but no tonneau is going to be 100% waterproof.
I'm sure from a technical/engineering perspective the relocated rails are not as secure, and someone with more knowledge could probably explain why. I don't know off-hand how much those rails are rated for, but earlier Tacomas they were only rated for 200 lbs, so they're not meant for securing super heavy loads anyway. If you're worried just go down to D-rings in the bed.
Josh256
Toronto, ON
2025 Tacoma TRD Pro
I have many cameras on my 2025 including the cab rear view camera and am certain it was available on select 2024 models as well.. I had originally ordered a 2024 TRD Pro with the same. That said, I can switch from cab to tailgate cameras in the "View" mode/app.. not sure if I can do this on the rear view mirror display itself but will report back.
Thanks for the review - I've ordered the same cover!
Josh256
Toronto, ON
2025 Tacoma TRD Pro
Update:
I've had the Bison flip back tri-fold tonneau installed for a couple weeks and love it. It shipped in Canada and arrived in ~4 business days. The provided tracking number was never updated past "preparing shipment", nor was the shop app any use logistically, making delivery/receipt difficult.
As noted it relocates the factory tie-down rails lower which blocks the 12v accessory lid.. notable: I'm still able to access the ports inside with the panel open limit at ~45 degrees. Quickest fix IMHO for those that want it to open further would be taking an angle grinder to the bottom of the Bison bracket to give the cover more space to open to 60-90 degrees. This is a 5min modification.
Another issue noted earlier that I suspect is common to many covers is the contact at the tailgate's top surface. If you have an electric tailgate it will sometimes catch when closing.. giving the tailgate a push or lifting the bison works fine. Any cover that watertight/seals the bed and/or locks for security purposes should engage the tailgate snuggly and have this issue. Worth the compromise IMHO
Back to the Bison rails (and relocated OEM tie-down rails): I *absolutely love* how each panel click/locks into place.. I've already driven with the first/rear panel flipped forward and this is a night and day improvement from my previous, overpriced dealer tri-fold cover - which essentially "floats" on the bed. This is accomplished by the bison rails (and relocated OEM rails) and the result feels very strong/secure, doesn't vibrate nor lift and IMHO is *by far* worth the compromise at the 12v accessory panel.
Thanks Duck Amuck for the review -
Josh256
Toronto, ON
2025 Tacoma TRD Pro
Video showing how each panel click-locks into place:
