Tekoma
- First Name
- Michael
- Joined
- Nov 22, 2023
- Threads
- 10
- Messages
- 145
- Reaction score
- 154
- Location
- North Carolina
- Vehicle(s)
- 2024 Tacoma TRD Off Road Manual
Don’t know that the OEM cover is advertised as easy to remove. It is a variation of the previous Gen MX4 cover. Despite how finicky the hardware is, it more robust than the former MX4 model. The old MX4 also had hand wheels in place of the nuts/lock washers. Toyota is clearly concerned about people inadequately attaching the cover given the fact that they even add cotter pins. I’ve had the previous MX4 (similar to OEM) on my last two Tacomas and never had to take it off.The only flaw with the otherwise excellent OEM cover is the attachment hardware. It's hard to install, and you'll drop washers more than once. Given this is supposed to be easy to remove/replace, the hardware is a bit of a fail. They should have used captured bolts on the cover with the correct spacers, and handwheel nuts underneath to make it removable without tools.
The new MX4 for 2024 much easier to remove/reattach. This is one of the few improvements I liked about it. It is also notably lighter which makes it easier to take off/flip open/closed but also means they cut some cost.
I ended up returning the MX4 due to the redesign allowing water to collect in the under side of the cross rails at the folds and pouring all over the bed when opened.
I have the OEM cover now and I’m much happier with the quality. Zero leaks and drop rails retained. I removed the silly emergency exit handle, drove me nuts whenever I fold the cover open.
