ridetime
Oklahoma
Nice! I have been planning to do this. What did you paint them with and I assume you left them on the truck?
dvrgz
dvrgz
Los Angeles
The bolts under the wheel wells I took off to paint. For the two larger bolts I left them on. Just masked them off. It’s 1 1/8 diameter. I attached a photo of the paint I used.
2024 Tacoma Bolts to Black & Visor Warning Removal IMG_5754
2024 Tacoma Bolts to Black & Visor Warning Removal IMG_8131
2024 Tacoma Bolts to Black & Visor Warning Removal IMG_5750
ridetime
Oklahoma
Thank you for the pics! I noticed the ones on the rear control arm the day I bought mine and thought it looked unfinished. I will add that to my project list for next weekend.
Kjc
Anc
2024 Tacoma OR
What's the trick with the visor stickers mine are glued on I think... Did you heat them up? Seems like they used to be on the inside now on the outside looks awful
Sner
Just removed the visor warnings
@Sagebrush +20 hp
I managed to get mine off as well, one was easier to get off than the other. A little dicey of a job. I’d say if the visor was exposed to any amount of sunlight, no way they’re coming off. It stretched the material on my visors slightly - but looks much better without those warning stickers.
dvrgz
dvrgz
Los Angeles
@Sner same with mine. Passenger came off no problem. Driver side was tougher.
@Kjc I used a heat gun and slowly peeled it off
2024 Tacoma Bolts to Black & Visor Warning Removal IMG_5769
Sner
Can't remember on mine which was worse, I am saying it was the passenger side. I pulled them off cold turkey while they were in place 😂
The bolts are a nice touch, but getting those ugly visor stickers off is epic. I have given up on other vehicles because they usually leave the visor material damaged. It looks like this is doable on a 4th gen and I will have to check this out.
