Towing without a Brake controller
Mark_Tacoma
Mark
Georgia/USA
2024 Toyota Tacoma 4x4 TRD Sport
Newbie question here... My 2024 4x4 TRD Sport doesn't have a Trailer Brake controller. :( What does this mean in terms of limitations for towing with this truck? Does this mean that I can't tow a trailer that has electric brakes, because it can't make use of them or control them? Should I limit towing to lighter trailers?
JBSwine
2022 Kia Sorento
It means if you have E brakes on a trailer then they will not work and the trailer will be pushing you when you try to stop. If you do not add an aftermarket brake controller then you need to tow something light weight that does not require a controller or a trailer with jake brakes.
brentbba
What been said about brakes is spot on. I don't know about I UT other states, but in Commifornia any trailer over 1500 lbs must have brakes, electric or surge.
mfat
Kansas City
4th gen
Someone please correct me if incorrect.
Surge brakes are mechanically operated with the braking system being entirely contained within/on the trailer. Operating when back pressure is placed on the hitch as a result of the towing vehicle slowing down.
2016 Tacoma
Curt makes a brake controller that plugs into the trailer connector. You plug the trailer cable into it, and it Bluetooths to your phone.
