- First Name
- Tom
- Joined
- Jun 27, 2024
- Threads
- 1
- Messages
- 103
- Reaction score
- 120
- Location
- Houston, TX
- Vehicle(s)
- 2025 Tacoma TRD Pro
I just ordered a set myself. I'm also guilty of buying parts & accessories for a Pro (I don't have yet).
Thanks for addressing.Valid questions. We have been designing and manufacturing Hood QuickLIFT systems for over 22 years, so we have some experience. Our system does not put any undo stress on the hood causing any potential buckling. If you look at the current Tundra, the OEM hood strut geometry is VERY similar to ours.
Judging by my truck I vote for the struts.The race is on, will these arrive first or my truck?![]()
I’d check out Chloe Kip’s one handed open and install video. Looks to be very easy to open; no shots of closing but using deduction from how easy they open…I like this version a lot, especially not needing to drill anything like the RC version. There is one thing causing me to pause about these, though. The attachment point to the hood is so far back that it must require a decent amount of force to hold up the hood causing an equally decent amount of force to pull it down. With the pivot point so far back combined with the force to pull down, I would wonder about potential buckling in the future. I've seen it before when these types of aftermarket struts came out. That said, things have changed a lot since then with lighter hoods needing less force than they would have in past years. All of that has probably been solved by now, but my mind can't help but go straight to "what if" sometimes. Experience, no matter how outdated, can't just be thrown out without at least some consideration when thinking about a brand new product. I can be very gentle with it but I do not trust the maintenance monkeys to do the same.
Really?While I have to push the hood down a bit to close it now, I wouldn't say the force needed is excessive. I would consider it similar to any other hood I have had in the past. The only clang I hear is the hood latch engagement when closing. On my vehicle, at least, none of this has caused any concern. Unfortunately, not being there, I don't really know what you are dealing with. You might reach out to Redline if you think something is wrong, they seem to be pretty responsive.
