Gear_yyc
I do find it funny that they are aware and have an explicit list of "potentially" affected VINs, but it is not a recall yet. Maybe I haven't owned (new) cars long enough, but that seems funky to me.
Likely based on risk analysis. There's no requirement to issue a recall if it's not a safety issue, and as long as the likelihood of a failure is below a certain threshold, it's in their best interest to just repair the ones that break rather than intervene proactively.
Comments to some previous posts:
1) If the transmission is not acting up or giving warnings (codes), the dealer will do nothing.
2)If a dealer tells you that "Hard shifting" is normal. Find another dealer.
3)Toyota Canada may put out their own TSB.
4)Refer to the first post for help. It's good to go.
Thirtywon
Ontario, Canada
2024 Tacoma TRD Off Road Premium
I was a fairly early delivery, so not surprised to fall within the scope of the TSB.
We have yet to experience any issues with the transmission, but relatively low KM so far as well. Does this mean that should the transmission fail out of warranty, we're covered due to the known issue? I know that is quite a ways off, but confirmation of this would provide piece of mind.
If you have the same standard powertrains warranty as in the states (5/60K) you should be okay. If it's going to fail, statistically speaking, it'll most likely happen before then.
Thirtywon
Ontario, Canada
We do, yes. 5 years/100,000km
Thanks!
TacoMagic
Joshua
SouthEast USA
2024 Tacoma SR5 4x4
Can someone explain what to be looking for if the transmission starts to fail? Does it go out at once? Just curious what to be looking for.
I had a 2018 Colorado with the shudder problem, and it was fixed with a TSB.
UT
Seems like the common issues start with hard shifts from gear to gear, usually 1st to 2nd. Ultimately leading to only being able to get into gears 6-8.
that_frenchman
Alex
Austin, TX
2024 TRD Off Road Premium iForce Max
here is the Tacoma 2024 VIN Decoder that I copied from another site
2024 Toyota Tacoma VIN Decoder
3TM = Toyota Mexico Baja Factory
3TY = Toyota Mexico Guanajuato Factory
J = XtraCab with GVWR below 6000 lbs
K = Double Cab with GVWR below 6000 lbs
L = Double Cab with GVWR above 6000 lbs
B = 278 hp AT (SR5/TRD Sport/TRD Off Road/Limited)
C/F = Hybrid (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited)
D = 228 hp AT (SR 8AT)
E = 270 hp MT (SR 6MT/TRD Sport 6MT)
A = XtraCab
5 = Double Cab
F = 278 hp 2WD (SR5/Prerunner/TRD Sport)
H = 228 hp 2WD (SR)
J = 27x hp 4WD (SR 6MT/SR5/TRD Sport/TRD Off Road/Limited)
K = 228 hp 4WD (SR 8AT)
L = Hybrid 4WD (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited HV)
N = Tacoma
_ = Check Digit
R = 2024 Model Year
M = Toyota Motor Manufacturing de Baja California Plant
T = Toyota Motor Manufacturing de Guanajuato Plant
The TSB has "B", "D", and "E" in the fifth slot. No "C" or "F" -- so no hybrids are included in the TSB
TIL I have the 588th hybrid Taco built based on this breakdown. That's kinda cool. This may be a reason why the hybrids were delayed, they may have seen some signs of this problem and made sure everything was retooled before starting hybrid/halo production. Sucks for those who were truly amongst the first 4G Taco owners tho..
Sner
This TSB says US and Mexico, so I don’t know if the VIN range applies to Canada? Anybody know?
Is there a separate one for Canadian VINs?
My truck is a Canadian vehicle and it falls into the ranges and prefix's so it'd apply to Canada... wonder in Canada if a cold snap is what's going to get the ball rolling on these transmissions.
