What is the build date? Can’t remember where but someone said the ADD fix was software that was quickly updated to the factory builds but was delayed to those in the wild, and often missed unless you ask the service to check for the specific update?If you’re up to speed on the TFL truck that broke and what the issue was, this seems to be the same thing. See video, at about 30 seconds you can see my front wheels lose power and hear what I believe to be the ADD break. I’m going in for a “diagnostic” appointment at Toyota tomorrow… which means laying on the frozen ground to remove skid plates tonight.
I went through the obstacle the other direction- started in 4HI, moved to 4LO, then had to lock diff to get out. On the return, I was in 4LO with locked diff and MTS deep snow from the start. Neither rear wheel had traction, and front wheels were both on icy snow.
After getting out (pulled out), I identified the issue fairly quickly since the truck looked and ran fine with the exception of 4wd. Computer would switch into 4HI/LO with no issue, and I could hear the electronic whir, but no engagement.
I’m going in first thing tomorrow morning- this should be covered by warranty. If anyone has dealt with Toyota and their diagnostic/warranty side, I’d love to hear your experience and any tips/precautions. As stated I’m planning to remove my RCI skid plates (engine through transfer case) since I’ve seen so many horror stories about having Toyota do it.
