2ndGen2TrlHntr
- First Name
- Alex
- Joined
- Nov 8, 2023
- Threads
- 9
- Messages
- 207
- Reaction score
- 335
- Location
- Denver, CO
- Vehicle(s)
- 2024 Trailhunter Bronze Oxide; 2018 Audi S5 tuned
One of the things that I am excited about and also have a number of questions about with the 2024 Hybrid option is whether or not you can use the power in the bed of the truck with the engine/ACC off. In the second gen (assuming other generations as well) it needs to be on to utilize the 400w inverter. There is also no standard second battery. So in order to use my fridge and any accessories I must run a dual battery.
I am getting the Trailhunter and with all the power options in the back (compressor, USB C, 12v, and 2400w 120v) I am wondering if anyone has confirmed if these will function without the truck either started or in the ACC position. Does anyone know for sure how this will work? I haven’t seen anything that really confirms but they market it as if it could be used for a fridge etc, but that’s not the case unless you can power it at all times. It seems like with the inclusion of a secondary battery and size of it there would be a way to use that independently. Hoping to avoid a dual battery setup if at all possible since my primary accessory that’s powered continuously is the fridge.
