I got my Baja Designes S8 mounted on my roof rack and am ready to wire it up. Based on their suggestion, I got the upfitter switch from BD which is supposed to ease integration with oem switches. Looking at my pigtail and the BD harness it seems pretty straight forward but wanted to get yall to double check me before I hook it up. Is it as simple as thick white to to thick white, green to green, and black to ground in the engine bay?
Bonus points: The light bar also has a backlight feature. Not sure if I actually want to use but if I did would I wire the green lead to as second switch/pigtail? This was mentioned by BD but same as above, want to run it by you guys first.
