Toyota would disagree with you. The manual says air compressor and the cover in the bed also says compressor I believe.
I don't recall the moonroof being an option.Interesting that your trail hunter doesn’t have the moonroof. Did you build sheet say the moon roof like others have?
There’s no such thing as a tire inflator that isn’t an air compressor. That’s how a tire inflator gets air into the tire, by compressing it.Call it what you will.. it’s Toyota Part # PT949-35240, made by NSV Auto.
If the quick connect at the compressor works, I don't see why not.Can you use a Moorflate type system with this compressor?
