brentbba
Brent
Toyota would disagree with you. The manual says air compressor and the cover in the bed also says compressor I believe.
2024 Tacoma Ice Cap White 2024 TRAILHUNTER Tacoma delivery! Proud new owner 🤩 20240622_130542
brentbba
Brent
Pic of the compartment in the bed says compressor too.😉
2024 Tacoma Ice Cap White 2024 TRAILHUNTER Tacoma delivery! Proud new owner 🤩 20240622_132832
brentbba
Brent
Book says 15 to 35 psi 2.5 minutes
larkhen
New Mexico
Accord
Interesting that your trail hunter doesn’t have the moonroof. Did you build sheet say the moon roof like others have?
brentbba
Brent
I don't recall the moonroof being an option.
StreeTaco
2024 Tacoma TrailHunter
Call it what you will.. it’s Toyota Part # PT949-35240, made by NSV Auto.
2024 Tacoma Ice Cap White 2024 TRAILHUNTER Tacoma delivery! Proud new owner 🤩 IMG_8807
brentbba
Brent
Not going to belittle the semantics of it. I had a Puma in my Landcruiser that had a small tank. It took the same amount of time to inflate a 33" tire, so I'm fine with this, tank or not. 😁
Dalingrin
There’s no such thing as a tire inflator that isn’t an air compressor. That’s how a tire inflator gets air into the tire, by compressing it.
AZTaco
AZ
Toyota
$1250 for that compressor is a little spendy. I see some dealers selling it for under $1,000 and I'm sure that includes all the trim pieces and the hose. Still a bit pricey.
Lower cost options would be using an OEM right side storage compartment and installing it on the left side to store a stand alone compressor. Or using the kits available to mount an ARB compressor. ARB compressor is about $360 and the mounting box is another $120. I'm guessing all new Tacomas have the same wiring harness and there is a pigtail on the left side with the appropriate gauge wire and fuse.
Or just suck it up and buy the whole trailhunter.
brentbba
Brent
I took last option and bought the Trailhunter! OEM compressor has some nice features. You can preset several inflation and deflation values so you don't have to monitor it. I haven't tried it yet, so we'll see...
