Engine Idle Warm-Up how long?
JayyNaj
Juan
Southern California
4 Gen Tacoma
How long do I have to warm up my engine , I have a 2025 tacoma Off Road trim , Im new to this toyota world and turbo engine ?
SnowmanJPS
Halifax, NS
2025 TRD Pro
This is what my 2025 Hybrid manual says, and we have the exact same engine, however I do notice better shifting of the transmission on cold days when I let it warm up before pulling away
Miqie
2024 TRD Sport-Bronze oxide.
Start it up, let it sit for a minute, then drive gently for till the temp gauge shows activity. The quicker the engine gets to operating temperature the better and driving it does it quicker than letting it idle in the driveway.
MustardTiger
Tundra/Ford/GMC
I see you're in California. In temps 50f and above, I would just get in and drive. Below that, use the lock/lock/hold to remote start it as you're walking up to it. By the time you get in and put your sb on...it'll be running for a minute which is sufficient. For me, in Canada, with subzero temps...the 10 minute remote start cycle is not near long enough, even being plugged in. But I'm talking temps -30f temps 🥶 lol. Regardless, immediately putting a cold engine under load will result in a very rich fuel injection map to compensate...and thus increase fuel dilution in your engine oil (not good).
If it's cold–well below freezing–I'll remote start to make sure the oil gets warmed up so the turbo gets properly lubed.
Otherwise, nope, get in and go.
Delirious
Nick
I always let it warm up if I'm jumping right on the highway.
It was always advised not to drive a vehicle hard until it warms up. with all that condensation in there.
Ever notice all that condensation dripping out of the exhaust in the morning or or anytime on a cold day?
Another important thing is not to turn the vehicle off immediately after driving aggressively or highway speeds because you want a turbo to cool down a little bit.
Speaking of Turbo, I understand it's necessary to keep the oil changed frequently because the turbo uses the same oil as the engine.
I heard it through the grapevine. so it must be true?
Kielly
Ryan
Alberta, Canada
2024 Tacoma Sport+ 6M
In the summer, start it up and wait for the RPM to drop to normal idle RPMs.
During my -40 winters, I idle her for roughly 20 minutes and she still don't show any engine temp until I get onto the highway about 3-4 minutes away of driving haha.
Gfenza89
Gary
2022 tacoma sr5
Let it run for a minute to properly get oil flowing then kinda take it easy. I’ve noticed with my truck that until the temperature comes up a little bit it will use the engine rpm to deliver the power instead of the turbo
