Rough transmission shifts
Burgi
NC
24 Taco
I think there is a lot of paranoia about the transmissions. I'm at 9k miles and mine is super smooth. I will say it took a few thousand miles for mine to learn my driving habits but all is good now.
From what I’ve seen on the forums it seems that when the transmissions fail they do it relatively early on within the first few thousand miles. I’m on my 3rd Tacoma now and I’ve always had positive experiences with Toyota when problems arise. My advice is to just drive your trucks and when something goes wrong have faith in Toyota to resolve the problem, no reason to stress about something that could potentially go wrong.
@Burgi I totally agree. I have only had a few problems with my Toyotas but every time I did they took care of me too.
My truck is almost here and I plan to just drive it and enjoy it and then deal with issues if the come up.
CanyonFisherSummitSeeker
Chapman
2024 Tacoma TRD Off Road
Almost every truck I've owned has some stiff 1-2-3 shifts first thing after a cold start. My 24 RAM 2500 did the same as did my 21 Tundra, 23 Tundra and so does my 05 Tundra and 06 Silverado. It takes a longggg time for the transmission to warm up compared to the engine. I wouldn't worry about it or waste your time at the dealer, they'll just say they didn't find anything.
I have to say it is more nuanced than that.
PA Dave
York. PA
2024 Tacoma SR
I’m having occasional rough shifts from 1-2 and 2-3 in the mornings or after the truck has been sitting a while. Once I’ve cycled through once it generally shifts very smoothly the rest of the drive.
I have taken the time to let the truck warm up, and it will still sometimes rough shift. I’ve also started it and driven without giving a few minutes to idle and warm up and it will sometimes shift smoothly even when not warmed up.
So I don’t really know what to think. Coming up on 4K miles. I’ll definitely bring it up with my 5k service but I fear unless they let the car sit overnight and drive it first thing in the AM they won’t experience the rough shifts. Disconcerting to say the least.
I have the same issue. That said, it should not do this. Good news for me is I kept my 2005 that has 235,000 miles and it has been totally reliable. The guys at the Service Dept want to buy it. Thing is Toyota's reputation is on the line.
Pootklopp
Usa
2024 Bronze Oxide TRD OR
Can someone describe what they mean by rough shifts?
Coming from manual transmissions I would describe it as the rpm's hang during the shift and the clutch is let out a bit fast causing a slight bump feeling.
Not sure if that makes sense.
frosty4x4
Midwest
Ah okay thanks! I was wondering if it was shifter feedback where it doesn’t feel like it goes into a specific gear smoothly. Sometimes happens to me on 2 -> 3 but not a big issue.
I still have the jerkiness in the morning going from park to reverse or drive. Trans is pretty smooth after that. 6k and no issues really.
ChrisC
Christy
Washington
Tacoma TRD ORP
Sorry I guess my comment was incorrect. I can manually put it into 1 and 2, but when first putting it into manual mode it always reports 3. I don't feel any engagement when stopped, but it's bad when moving, even slowly. I'll see if I can find a safe place to grab a video after I pick it up from the dealer.
That’s normal for it to start in S3. Says it will right in the owners manual. Go to the manual shifting section of the manual.
thor’s taco
Indiana
2025 Tacoma TRD Sport
Anyone have any updates on this? I just purchased a 2025 TRD Sport 2 weeks ago. Have less than 500 miles on it and I’m experiencing all the shuddering/rough shifting that people have been describing.
Rough shifts until about 25mph, including downshifts when coming to a stop. And about 50% of the time I get a loud “clunk” sound in the drivetrain after coming to a complete stop. Almost like the truck is trying to lurch forward.
The truck didn’t start doing it until I hit around 300 miles, and is making my experience less than enjoyable. I’m worried that if I take it to the dealership, they will give me the run around and say this is normal. Thoughts?
BAQ717
‘24 Tacoma TRD OR
The only time it’s “acceptable” to have a rough shift or two is on a cold drivetrain. Anything other than that you should be at the dealer. Good luck
You can take it to your dealer, but be prepared for them to tell you that is normal. Just check in with @Gfenza89 if you want to hear the long term run around he has had. He finally got his dealer to call in a factory tech, who agreed that bucking and lurching at slower speeds is perfectly normal.
On a hopeful note, mine started fine and then got into nasty shifts like yours at about the same mileage. It did that on and off until it got to about 1,500 miles and now it is back to shifting normally. The same transmission is in several Toyota/Lexus SUVs and there have been complaints about their shifting now for years.
Good luck and let us know how that goes.
TCW1184
I've been considering 4th gens, and I was looking into peoples feedback on the transmission beforehand. It's really unfortunate that Toyota keeps designing stuff this way on purpose. What's being described here is exactly what I experienced with a previous Highlander 8 speed. Super clunky 1-2 sometimes 3, mostly fine after that. Toyota never did anything with it. Gave me the typical "normal for this vehicle". Master tech at Toyota said they don't really slip the torque converter anymore for smooth shifts because that's inefficient.
It's easy to blame the EPA, but that hasn't stopped other OEMs from making smooth shifting trucks.
thor’s taco
Indiana
And that is exactly what I’m experiencing. I will say, sometimes I feel like I’m too heavy on the pedal and that can lead to these rough shifts. But I shouldn’t have to worry about that on a 50k truck. I love every bit of the truck besides how it feels when shifting at low speeds.
Some other threads have talked about letting the transmission warm up. I remote start my truck and then drive for about 15 minutes and the transmission temps are still nowhere near the middle of the gauge. Once it is up to temp, after about 30 ish minutes of driving, it shifts much better overall.
TCW1184
Good that it at least gets a little better with temp. The only thing that stinks about that is by the time it's warmed up and maybe shifting a little better, you're already where you need to go, and it's same thing on the way back (i.e. work). I traded out of the Highlander because of this issue. loved everything else about it but that. Constant clunking through stop and go traffic gets really irritating. Bought an e-CVT Highlander Hybrid and obviously that went away.
