Running Air Compressor in Hybrid?
taco_pd
Paul
Salt Lake City, UT
24’ Tacoma TRD OR iForce MAX
Anybody think its a bad idea to run an air compressor off of the relay fuse box thats for jumping the car? The 12v under the rear seat is pretty inaccessible. The cap that flips up is used to jump the car and presumably connects directly to the 12v battery.
So looking for a good place to run the compressor.
2024 Tacoma Running Air Compressor in Hybrid? IMG_1655
StreeTaco
TN
2024 Tacoma TrailHunter
Where would the compressor be located?
taco_pd
Paul
Salt Lake City, UT
i have an external compressor that connects with clips to the battery terminals. I just wanna run that for now instead of mounting a compressor in the engine bay
trailhunger
US
2024 TH
You could* but why bother popping the hood every time when you could use the bed's 12V port and get a connector or solder inline a 12V cigarette lighter adapter to the compressor?
taco_pd
Paul
Salt Lake City, UT
I actually tried that exact approach. Bought a 12v cigarette to clips on Amazon. Attached the compressor to the dc plug in the bed. Unfortunately the compressor pulls 10 amps and the fuse for those plugs have a 7.5 amp fuse so it instantly blew the fuse which I then had to replace.
trailhunger
US
2024 TH
wow... wonder why it's got such a low amp fuse on there. I guess I won't be lighting cigarretes from the tailgate lol 🚬
the 12V bed port might have its source power coming from the starting battery. I am curious what peak wattage it puts out on that side.
IDK man, unless the back of center console is different amp fuse sounds like your compressor is designed to take direct load from 12V starting battery.
Independence Overland
Tyler
Fj Cruiser
cigarette lighter ports arent good for higher amperages, thats why compressors come with the clip connectors. My single piston ARB draws around 20-25amps if memory serves.
As for the compressor, you should be fine doing that. Jump starting a vehicle is 500-700 CCA so a measly 20 amps or so from a compressor shouldnt be any issue for that little jump start tab.
Duce95
Big Deezy
Arizona
2024 TRD Off-Road Premium
I went a different approach based on the new Viair 88p with 7pin connection.
I snipped off the clips and wired it to a 7pin trailer plug. Easy high powered plug in the back of the truck.
2024 Tacoma Running Air Compressor in Hybrid? IMG_4728
2024 Tacoma Running Air Compressor in Hybrid? IMG_0021
trailhunger
US
2024 TH
yea I still circle back to fact you gotta open the hood and this panel just to air up & down, on a dusty trail, messing with this fuse box every time. No way man
You have an iForceMax 2400w inverter correct? These new dual DC/AC compressors are killer, but to use the DC current they require 15A cigarette lighters. I'm probably gonna bump up my TH's DC-side 12V bed port fuse; plan on running a 12V heated mattress off that side, power station off the AC side. 7.5 amp is weak sauce. Check your center console fuse rating, maybe it's higher in the cab
taco_pd
Paul
Salt Lake City, UT
You have an iForceMax 2400w inverter correct? These new dual DC/AC compressors are killer, but to use the DC current they require 15A cigarette lighters. I'm probably gonna bump up my TH's DC-side 12V bed port fuse; plan on running a 12V heated mattress off that side, power station off the AC side. 7amp is weak sauce. Check your center console fuse rating, maybe it's higher in the cab
ya if you or anyone else has any dc/ac compressors they recommend would welcome those recommendations here. All the ac compressors on Amazon I’ve found aren’t fast enough for off road use so if there are newer and better ones I can look into that. Thank you.
trailhunger
US
2024 TH
Also, apparently engineering has said the Trailhunter's compressor will be an available option on the non-TH trims. So the wiring is preloaded in the bed wall somewhere. Probably just need to locate it, test it, etc. (should be dialed into your aux switches maybe?)
I think others have done aftermarket compressors on their trucks here with that same available power source intended for the TH compressor. Need to dig into the forums a bit.
GL
I stuck a single ARB in mine. I've got a non-hybrid, so the electrical was simple. Designing the 3D printed mount was a multi-prototype project.
2024 Tacoma Running Air Compressor in Hybrid? NjAnTgB
SaltyToad
Todd
Salt Lake City
2024 Tacoma Off-Road iForceMax
A variation on the original question though, in the hybrid situation, if you had a portable air compressor with clips, would you hook the positive to the piece under the red cap in the fuse relay box? And hook the negative clip to the piece of metal in the engine like you would if you were jumping it? The air compressor would work fine? It’s obvious in a non-hybrid situation but this is obviously set up differently.
I’m not versed in amps etc and don’t want to mess anything up. If you don’t have onboard air, there are no obvious alternatives. I was on the trail last weekend with friends and hadn’t realized it was so different until I went to air up fortunately I used their batteries
2024 Tacoma Running Air Compressor in Hybrid? IMG_6908
