- Joined
- Apr 17, 2024
- Threads
- 20
- Messages
- 259
- Reaction score
- 325
- Location
- Chicago, IL
- Vehicle(s)
- 2024 Tacoma Limited
Correct, all the grills are interchangeable. Toyota does have an OE lightbar that connects into the highbeam circuit, but I'm not sure it's even available. I made my own brackets for Heretic bar as well as the front-facing camera. Yes to the harness, had to get a new one. I have a couple other threads discussing the installation of those parts.Grill:
I like love the idea of the Grill/light bar combo as part of the blackout transition. Any info on tips or lessons learned is appreciated. Are the grills pretty much interchangeable (attach points, etc) or is there more serious work to be done there? And the lights...guessing that power/harness was all new?
Same boat, been there, just get the handle overlays. The ones I got were like $26 bucks or so shipped and I think they look perfectly fine. You can try wrapping but the keyhole will definitely be a bit tricky.Handles:
The purist in me wants to replace them...but I hate tearing into a new door even more. So I am thinking about wrapping them (anyone done that)? I have applied Scotchcal protective film on lots of fun surfaces...so it seems plausible. The plastic covers are intriguing because of the simplicity....are they bulky or lose fitting? They seem popular but I don't want to negatively affect the feel of such a practical feature of the truck (i.e getting in).
265/70R18 will fit without any modifications. It's actually the stock size for the hybrids with 18s. I originally wanted +38s as I too did not want that much poke. But I found these +32s from a guy in Japan that were "old-new" stock, I guess a special order for someone that cancelled. Was definitely a pain as I had a bit of an issue with customs getting them in, but nevertheless, was really happy with the fitment with the 265 section tires.Wheels/Tires (specifically for bumping up from stock 265/65R18 to 265/70R18)
Lots of options there, but I was curious about Gurvy522 opting to move the tires out 22mm (offset change from stock). When you factor in the wheel width change (from 7.5 stock to 8.0), I think you end up picking up 17mm of clearance on the inside and push the outside of the tire out 29mm (a little over an inch). Was there a method to the madness...like need clearance or does the 265/70R18 fit without the offset/width changes? How is the "poke"...I did not seem much if any from the images...but the math says they should have moved out a bit at least. Looks great btw...just curious if it was intentional to get clearance for some reason.
285/65R18 is the largest width you can go on stock suspension and wheels. Lot of OR guys are running 285/70R17 on their 17s. I considered 285s, but do a lot of towing and decided on the narrower tires for slightly better economy - as well as better performance in the snow.Bonus points if anyone has knowledge around the widest 265/70R18 (32.6 dia) that has been successful on stock LIMITED wheel (18' dia, 7.5" wide, 55mm offset)
I dug heavily into TIS to see if there was some calibration process - there is not, surprisingly. They do list a margin of error for speedometer differences (I think it was 4% or so), and on the 33s I noticed the speedo was reading approximately 1-2MPH slow at 63MPH compared to GPS. It's really not a huge deal and I wouldn't worry about it too much.Speed/Odometer Cal
What is the consensus on recalibrating the speed/odometer after bumping up to bigger tire diameter(s)?
