Bravada
S.E. Texas
2024 Taco Limited i-Force Max
I took possession of my TRD-OR/MT truck yesterday. Drove it home from the dealer around 250 miles and got 21mpg. Truck bed will be covered with a canopy camper from Dirtbox.
Today ...
  • Installed the OEM front molle panel. It will hold my 13 gallon water tank and the RV water pump.
  • Installed driver's side Rago molle panel. It mounts my CO2 and propane bottles.
  • Pulled the thimble sized oil filter off (90915-10009, aka N1) and replaced it with the larger F1 filter to see if it fits. No problem.
Thanks for the heads up on the larger filter.:fistbump:
Pappy
Jon
Albuquerque, NM
The -10010 is also an option. It's used on the turbo V6 in the Tundra and Sequoia.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 F1 vs 10 vs N1-sm
Devildog81
minnesota
2024 tacoma trd offroad
Which Icon wheels are those? What’s the offset?Do they poke out past the fender flares a lot?
I,m wanting to run the same tire on new wheels, but unsure on what specs/offset to get and have minimal poke.
Thanks!
I’m running the same icon wheels, recon SLX +25 offset.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 IMG_5689
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 IMG_5695
Miqie
2024 TRD Sport-Bronze oxide.
Today ...
Thanks for the filter update. Read about this on another forum but no one knew if the longer filter would fit. They also wondered if the bypass valve of the larger filter would operate different for this engine. Also, the larger filter may be a resin vs. pleated filter of the N1, (if that makes a difference in filtering).
Pappy
Jon
Albuquerque, NM
Thanks for the filter update. Read about this on another forum but no one knew if the longer filter would fit. They also wondered if the bypass valve of the larger filter would operate different for this engine. Also, the larger filter may be a resin vs. pleated filter (if that makes a difference in filtering).
My wild guess is the N1 and F1 are identical internally, except for the length of the media. I will be cutting my F1 open in July when I give the truck a break-in oil change. At some point I will cut open a -10010 filter. I'm guessing it might be a resin element based on what I've seen in the past from some Denso Japan filters.
Pappy
Jon
Albuquerque, NM
Back at it. Yesterday and today ...
  • Installed Victory 4x4 sliders.
  • Installed the "smaller" Canada mudflaps (PK389-35R00-P1).
  • Removed resonator and installed the TrailHunter exhaust tip (PT226-35241-AA).
  • Wired the rock lights on the Victory 4x4 sliders to Aux2 dash switch.
  • Wired a relay off the Aux3 switch for future ... cuz it was there and I could.
The provided wire pigtail for the Aux1-3 switches. I installed a 4-pin Weather Pack connector. Currently Aux2 is wired to the rock lights on the sliders, and Aux3 is to a relay (for future). Aux1 will be for the driving lights on the front bumper.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 Aux pigtail-sm
The Aux3 relay mounted on driver's side fender, triggered and grounded.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 Aux3 Relay-sm
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 Victory slider-sm
