OEM mudflaps. Canada vs US.
Any chance they have you the spec difference or what matches to which trim level? Wide/narrow honestly means nothing - too subjective. 17 vs 18 or less than 30 offset more then 30 offset... Those are objective characteristics that can help determine "correct match".
Such as if the "wider" one on an 18" stock offset of 55 pokes out, or stops clean.
I don't have specifics regarding increased poke or wider than stock tires or wheels with different offsets. I think the narrower flaps would only work for trucks with relatively narrow tires from the factory. I attached two pictures comparing US stock versus the Canadian flaps on my Pro. Anything much wider than the Pro/TH OEM fitment would probably need a aftermarket flap IMO.
2024 Tacoma OEM mudflaps. Canada vs US. Rear Old:New
2024 Tacoma OEM mudflaps. Canada vs US. Front Old:New
saerandy
Randy
Richmond, VA
2024 SR5
It’s more about the fender flare that you have on the side of your truck. So the TRD Pro and Trail Hunter would be the ones for the larger flaps and SR5 and any of the other trucks that don’t have that added flare on the side would take the other version. The different widths actually correspond to the fender flare width.
I agree @saerandy.
If you change out the wheels and tires on your truck beyond what comes from the factory I don't think even the wider flares would be enough. They barely cover the OEM tread on my truck. There are good aftermarket choices out there to consider for trucks with even more poke.
I was wondering whether this would be a good reference marker as well (at least from OEM setups). That PRO and TH need the "wider" set and all others need the "normal" set. I don't know the spec on the PRO wheel stock, but I know the 18" Limited offset is 55, the 18" TRD matte black wheel is 45, and the TH 18" wheel is 20.
Sounds like unless someone is in the PRO or TH stock category or has moved their setup to be near there, the larger set may be too large and create flap/catch on the outside of the wheel.
HCTacoGuy
Jerry
Pa
2025 Tacoma TRD Sport
I have a TRD Sport with Method 703's +35 with 285 70 17 Falkens. I went to the dealership yesterday to checkout the PK389-35R00-P1 flaps they had in stock. They almost covered the tread on the front but from what I have read, PK389-35R50-P1 are wider. I ordered the PK389-35R50-P1 from the dealer for 112 and change, as soon as they come in I will install them post a pic of the coverage. Supposed to be here in a few days.
rijc99
4G Tacoma OR Premium
Looks like you're running the Matte Black TRD wheels 18x8, 45mm offset. Is that correct? As that'll be the match for my expectations.
18x8.5 with 20 mm offset according to specs on ordering page.
Wonder what your part number is then. As that's two wheels with very similar appearance but different offsets. The specs you quote are what I know for the TH styled wheel.
Part PTR56-35242-F1 is TRD WHEEL: Flat Black = 18x8, 6x139.7, 45mm offset, 95.1mm bore. These are the wheels I have, so I know the spec is correct.
rijc99
I have the TRD Pro wheels with 265/70R18 tires. PT946-35240-2F.
2024 Tacoma OEM mudflaps. Canada vs US. IMG_2344
