Which site?$102.50 no tax, no shipping
I don't have specifics regarding increased poke or wider than stock tires or wheels with different offsets. I think the narrower flaps would only work for trucks with relatively narrow tires from the factory. I attached two pictures comparing US stock versus the Canadian flaps on my Pro. Anything much wider than the Pro/TH OEM fitment would probably need a aftermarket flap IMO.Any chance they have you the spec difference or what matches to which trim level? Wide/narrow honestly means nothing - too subjective. 17 vs 18 or less than 30 offset more then 30 offset... Those are objective characteristics that can help determine "correct match".
Such as if the "wider" one on an 18" stock offset of 55 pokes out, or stops clean.
It’s more about the fender flare that you have on the side of your truck. So the TRD Pro and Trail Hunter would be the ones for the larger flaps and SR5 and any of the other trucks that don’t have that added flare on the side would take the other version. The different widths actually correspond to the fender flare width.Any chance they have you the spec difference or what matches to which trim level? Wide/narrow honestly means nothing - too subjective. 17 vs 18 or less than 30 offset more then 30 offset... Those are objective characteristics that can help determine "correct match".
local dealer gave me a dealWhich site?
I was wondering whether this would be a good reference marker as well (at least from OEM setups). That PRO and TH need the "wider" set and all others need the "normal" set. I don't know the spec on the PRO wheel stock, but I know the 18" Limited offset is 55, the 18" TRD matte black wheel is 45, and the TH 18" wheel is 20.It’s more about the fender flare that you have on the side of your truck. So the TRD Pro and Trail Hunter would be the ones for the larger flaps and SR5 and any of the other trucks that don’t have that added flare on the side would take the other version. The different widths actually correspond to the fender flare width.
Looks like you're running the Matte Black TRD wheels 18x8, 45mm offset. Is that correct? As that'll be the match for my expectations.PK389-35R50-P1
McGrath Elmhurst Toyota
Ordered 1/20. Received today.
18x8.5 with 20 mm offset according to specs on ordering page.Looks like you're running the Matte Black TRD wheels 18x8, 45mm offset. Is that correct? As that'll be the match for my expectations.
Wonder what your part number is then. As that's two wheels with very similar appearance but different offsets. The specs you quote are what I know for the TH styled wheel.18x8.5 with 20 mm offset according to specs on ordering page.
I have the TRD Pro wheels with 265/70R18 tires. PT946-35240-2F.Wonder what your part number is then. As that's two wheels with very similar appearance but different offsets. The specs you quote are what I know for the TH styled wheel.
Part PTR56-35242-F1 is TRD WHEEL: Flat Black = 18x8, 6x139.7, 45mm offset, 95.1mm bore. These are the wheels I have, so I know the spec is correct.
