CATOY
Blind Spot Monitor
I like having the BSM and have a couple other cars with it. I prefer the system in my 2021 Mercedes GLE450 where it lights up red and makes an audible noise and the one in my 2013 Lexus GS350 that lights up brightly. The one in the Tacoma is not as bright as my others yet I'm glad I have it. I just wish it was a little brighter and made a noise or shook the wheel.
Digital Review Mirror
I chose the premium package mostly for the digital rear view mirror, that said it does take a couple days to get used to and I am currently only using it in the day time as the regular mirror works a lot better at night in my opinion. It nice to look and only see what;s behind you and not who's sitting behind you or the rear window with the smaller opening section. One other draw back is you can't check to see if you have something in your teeth unless you switch it to non-digital mode. The digital mirror probably will not work if install a shell or canopy back there. It also looks like the person behind you is in your bed when they are actually several feet behind.
Backup Cameras
The premium and Off Road model come with numerous view angles. The front and rear cameras each have three different angles and the multi terrain camera allows you to see what's under your car after you have driven a couple feet after turning it on. My camera is set to turn on every time I get below 12MPH which may be a little excessive. It is nice to see how close you stop to those limit lines at a light or stop sign. The rear bed camera is nice to have setup while you are driving so you can press the button and verify your load is still back there while driving. The display stays on for a couple seconds. I also noticed today that you can get a very nice trailer hitch view when you have your tailgate down, just make sure it won't interfere with your trailer. I haven't tried using any of the actual trailer assist or camera angles yet so I can't speak for those.
Full Speed Range Dynamic Radar Cruise Control with Lane Departure
This is my favorite and works better than I expected. My 75 mile a day commute is mostly freeway in heavy traffic and my truck does 90% of the drive on it's own. You just set and start it and it will control the gas, brake and steering for you. You need to keep your foot near the brake just in case and touch the steering wheel about every 15 to 20 seconds. The technology is great and I winder how it compares to a Tesla. The only times it doesn't work is when you come up to stop sign or signal so you need to be alert. It would be amazing If it was able to stop without a car in front. The lane departure is pretty good for the most part, it will gently keep you within your lane, i did notice yesterday evening on a 90 mile freeway drive that it likes to try to center towards the right when you are in the slow lane and the entrance and exit lanes are wider than the rest so be careful when you are using it as an office may thing you are drunk.
Road Sign Assist
This feature works as expected and is a nice feature
Automatic High Beams
This is a hit or miss so far as it has mostly activated in neighborhoods and again could get you pulled over for driving with your high beams as officers are probably not keen to this feature yet.
Lots of other features
There are other safety features that I hope I never need like pedestrian and rear traffic alert.
Backup Cameras
Road Sign Assist
