Explain it like I’m 5 - bump stops!
Wutangz_Taco
Andy
2024 TRD Pro Tacoma
Why do people keep saying the Tacoma had no bump stops. Is this true? Is it true across trims? I have a Pro soon to be delivered and I do not believe this is true at this trim level. Thanks in advance!
Lando
Corrected with updated info Aug. 19:
The new Tacomas don’t have external bump stops mounted to the frame in the front. They are internal to the shock In the Off Road. The Pro has shock mounted external bump stops I believe.
Wutangz_Taco
Wutangz_Taco
Andy
2024 TRD Pro Tacoma
The new Tacomas don’t have external bump stops mounted to the frame. They are internal to the shocks. I believe this to be true in all trims, but the Off Road and Pro for sure.
does this mean my new truck will fall apart when I drive it down our alley? /s
Gurvy522
Chicago, IL
This is only true for the front - the rear still has externally mounted bumpstops.
Tacomaniac
Kelowna, BC, Canada
Tacoma 2024 OR Hybrid
Correct (rear bump stop on the Off-Road model). The Bilstein front shocks have an internal bump stop. Not sure about the Foxes on the Pro though.
2024 Tacoma Explain it like I’m 5 - bump stops! 36CBB61D-CFEB-4426-89F4-CE8661FC8D00
Ron
Vancouver Island
Internal front bump stops seems like a very odd place to cut corners. They already had it figured out in previous years and it's not a costly bit of gear.
So, if you replace the Bilstein's you have no front bump stops, yes?
Sner
No …. All replacements would have them too - whoever makes it.
This isn’t a big deal to have bump stops incorporated into the shock. EVERY McPherson strut has bump stops part of the assembly - since the dawn before time. Problem here is the two piece top - and I’m not convinced it’s two pieces as much as it’s one piece of aluminum that’s failing in such a way that it looks like two pieces.
hemlockz
‘24 TRD Offroad 6MT
As I have come to understand it (and I might be wrong, maybe someone can confirm?) one advantage to the integrated bump stops up front is it solves one of the concerns with front spacers: you'll no longer need to get taller bump stops to be paired with your leveling kit or top hat spacers to prevent over extension of the shock. Its limits are already built into the shock so it's much harder to blow it out by overextending it.
CuriousTaco
Seattle
TRD OR Base
I thought it was mentioned elsewhere the Pro and Trailhunter do not have internal bump stops on the fronts? Only applying to the TRD OR...
Lando
Correct. I did more research, the Pro has shock mounted bump stops but they are external to the shock in the front.
