trailhunger
2024 TH
My TH (and most THs in the wild) are in the range. Gonna drive it until it codes. Whatever. Getting a 7 year extended. Old full size still runs fine.
‘hybrid module replacement’….Is that the entire electric motor assembly that interfaces w/the transmission?
@trailhunger Yep - it is the electric motor that is part of the transmission assembly. I believe the replacement transmission come as one unit with the torque converter, hybrid motor and transmission. That is a good thing IMO because it makes the replacement a fairly simple parts swap, with no major component disassembly involved.
Gfenza89
Gary
2022 tacoma sr5
No word from dealer yet
tacoboutit
2019 Honda Civic EXL
CTTO.
photos were grabbed from Facebook group, I posted it here to make everyone aware of it.
Hybrid models are now included on the list.
Call me a noob but I have no idea how to tell if mine is affected. My VIN: 3TYLF5LN8RT008605
nosirrahdrof
Wisconsin
2007 Toyota 4Runner
Trucks are produced sequentially. The top of the TSB states "This bulletin applies to vehicles BEFORE the production change..." So if the last 6 of your vin are higher than the number in the bulletin then you are not affected. If the 6 numbers are smaller, then you are.
tacoboutit
Thanks! This helps a ton!
UT
They just called and said, couldn’t duplicate concern. I knew that was coming
I am absolutely SHOCKED.
Actually, I'm not shocked at all. Toyota is not going to do anything for any of your transmissions until and unless you have the DTC listed in the TSB.
@Gfenza89 That was my best guess too. Just plain shitty shifting is apparently normal, but only in some trucks. I assume the debris has compromised the functionality of the solenoids but not enough for them to get stuck and throw a code.
As far as I can tell the short answer is that you are basically screwed.
