2024 Tacoma Integrated Bed Scene Lighting
brentbba
Brent
2024 Tacoma Trailhunter
Latest update is that the bed rail 'should' be in between the 13th and 28th. LOL!! We'll see...
Nvideon
Boynton Beach FL
2024 Tacoma TRD Pro
My Trailhunter came with the bed scene lights in the rails but it was not an option on the truck. Did I just get them? Hard to believe that, but no idea how to turn them on since they are there. As said above, need a wiring harness from dealer??
Sorry for the late response lol I believe the bed scene lights are standard for the Trailhunters
WKTJR1
Maine
There are published PNs for the lighting but nothing shows when you try to search the numbers.
brentbba
Brent
I'll post a part number when mine ever comes in and I remember to do it!šŸ˜„
brentbba
Brent
New estimated date from dealer is September 4-11. All the available units must be going to manufacturing plants.
vberber
Victor
Stockton, Ca
2024 Tacoma Trd Pro
Crazy,
the guy doing my ppf said he saw these plugs when they removed the trim on the top rails. Wonder if these are connectors for the lights.
2024 Tacoma 2024 Tacoma Integrated Bed Scene Lighting IMG_9132
2024 Tacoma 2024 Tacoma Integrated Bed Scene Lighting IMG_9131
brentbba
Brent
Crazy,
I wouldn't be surprised at all given that the bed scene lighting is an option. Probably one wiring harness for all the trucks. I know on m y old Landcruiser that the wiring harness was there for items like the hi range center differential lock button. Standard for everywhere but the US market. Easy add.
Supertech1
Arkansas
2024 Tacoma TRD ORP
I’m interested in doing this just to remove the ones that came on the truck with crappy fitment & are lifting near the cabin.
I’ve owned a couple 3rd Gen Tundras and 4th Gen Tacomas, all had this bad fitment you refer to, except the TH bed scene rails. They fit perfect, no lift.
I’m not sure if this is due to better design, or the fact the sport bar mount kept pressure on the top of plastic while summer heat helped mold the plastic cap, IDK?
andrewleader
Andrew
Washington State
Does anyone know if the bed scene lighting turns on when you approach the car, or when you unlock the car with the remote?
Or are the only options to have it turn on when the tailgate is open, or manually via the on/off switch in the cab?
If it's set to the Door setting, does it immediately turn off once you close the tailgate? Seems a little silly if so... ideally I would hope the bed scene lighting stays on for at least 30 seconds after closing the tailgate (since I would think the use case is "It's dark out and I just closed my tailgate and am going to walk around to my driver's door and would appreciate the additional light while walking over there"). I feel like these lights could be really useful IF they're well integrated, but idk how well they work? So little info online.
brentbba
Brent
On, off and door. I do recall them staying on thec30 seconds a d on with the tailgate down.
