$50,000 and no LED Daytime running lights!
SnowmanJPS
Halifax, NS
2025 TRD Pro
Here I am wishing I could get the non led DRL’s on the pro ? I like the 2nd gen style of the amber DRL
Miqie
2024 TRD Sport-Bronze oxide.
I think the Lasfit company that advertises on here has DRL when you switch to their LSD turn signal bulbs.
Korywithak
Kory
Harrisburg, Pa
2024 TRD Sport premium in windchill
^^^ yep. I now have led daytime running lights. Nothing like the pro but better than amber halogen.
2024 Tacoma $50,000 and no LED Daytime running lights! IMG_1053
Benny
Jay
Oregon
$2,468.26 for a pair of Limited Headlamps with sequential LED turn signals. Part# 81150-AK020 (Left) & Part# 81110-AK020 (Right)…. Damn! BIG QUESTION IS… are they Plug-n-Play?
2024 Tacoma $50,000 and no LED Daytime running lights! IMG_0083
ridetime
Oklahoma
I'm betting they would not work properly. The are LED and the Off Road's are incandescent. Even if you got them installed they would likely hyperflash or do some other weirdness. That's alot of cheddar to role the dice on a non returnable electric part.
R00F_K0REAN
Tyler
NJ
I just came here to say. I may be wrong. But I remember reading somewhere if you leave the headlight in auto. In drive. I believe the lo beams acts as a set of DRL while you drive.
Yotota
Zane
SW WA
24 TRD
Gonna just block the daylight sensor.
Just turn off DRLs in the settings if you don't want them on. The light sensor affects quite a few things.
Yotota
Zane
SW WA
24 TRD
I want them on and my OR does not have them.
Your truck has DRLs. They all do. Most are the headlights running at a reduced brightness.
But if you want your lights always on full brightness, just leave the headlight switch in the ON position.
They will turn off automatically after a minute once you lock the car, or you can push the lock button twice to turn them off.
I personally hate DRLs that run the low beam - it cycles the headlights on and off way more than usual, and they will dim and burn out much faster. On my truck the LED headlights don't have replaceable bulbs so I'd REALLY like to avoid that.
MHG
Mark
Long Island
2025 TRD Offroad
I stand corrected.
in all the vehicles I ever owned equipped with DRL’s the “auto” position is what turns on the headlights and tail lights when it gets dark, the “ON” position (or the one with the little pic of the headlight) turns on the headlights and tail lights, and in any other position, the headlights come on but the tail lights do not. So in my wife’s Honda the while LED stop is the only thing that comes on and it does so when the engine is running.
If Toyota is using the “ON” position and then it turns off automatically, this sets them apart from other manufacturers who to this day have a chime that goes off telling you that your headlights are on.
My dealer told me leave it in the Auto position and the DRL’s are automatic but they were mistaken as Auto does not.
MHG
Mark
Long Island
2025 TRD Offroad
Well found the off switch. Written on the bottom where is tall and folks with bad eyes can’t see it. Also tried turning the lights on as suggested and the vehicle chimes when I turn it off. Seems like a swing and a miss Toyota.
2024 Tacoma $50,000 and no LED Daytime running lights! IMG_4975
2024 Tacoma $50,000 and no LED Daytime running lights! IMG_4976
