Even at that priceMine's $51,500.
That's wild. Engine assembly issue? Really sorry you drew the short straw on this. Hopefully they get it fixed quickly.Just had it towed to dealer this morning.
Got a call a couple hours later: rear main seal leak is suspected. They ordered parts and should arrive tomorrow they say. I asked how this can happen on a brand new truck if its passed PDI? They had no words. I'm frustrated and angry. They said thankfully the oil levels were fine and not low so engine should not have been compromised but I am still not happy how this came to be.
Thanks for the letting us know. That sucks - you sure ended up with short end of the stick. It's a big job to fix rear main. Have to wonder how a rear main seal failed at such a low mileage. I hope they check crank end play to make sure it isn't shifting causing the crank to laterally move in the block and dislodge the rear main seal.Just had it towed to dealer this morning.
I'd be contacting Toyota Canada on this one - that's pretty unacceptable. Read on this forum some other guys truck was bought back for a cracked evaporator box leaking water onto passenger floor. AttachedYeah they said it's still a guessing game until they can inspect it closer once parts arrive. I asked what parts were ordered and they said a gasket? I asked is this a blown gasket cause that would be more than just a seal leak. They weren't sure.
I will decline the vehicle if there was a major engine issue like a blown gasket on a brand new vehicle under 20km. Really hoped this wasn't a major issue but this seems closer to worst case scenario than I had hoped.
I'd just say take a deep breath for now. If it's a rear main seal, it's not the end of the world for you by any means, and it's largely going to be a problem for them because of the labor. Something like that probably hasn't messed with the engine internals. And it may not be a blown gasket; maybe it just got pinched in the assembly process. Annoying, for sure, but don't go to the dark side just yet.Yeah they said it's still a guessing game until they can inspect it closer once parts arrive. I asked what parts were ordered and they said a gasket? I asked is this a blown gasket cause that would be more than just a seal leak. They weren't sure.
It’s either pull the engine or pull the transmission - they’d be pulling the transmission to do the job. Good idea and as for some extra warranty coverage if they can’t or won’t replace the truck.do you have to pull the engine to get to the seal?
OP if you do have to keep this vehicle squeeze Toyota for the 10 year 125k platinum warranty.
Yeah I agree with you- if I wanted to climb under my vehicle after working at my own job all day, I’d have bought a used vehicle.Unfortunately I have neither a jack or the ability to slide under to remove the skid plates at the moment. At this point I'd rather not touch anything and let them find the problem in case they try to place blame on me
Honestly this is unacceptable for a new truck. Really questioning Toyota reliability nowadays....Just had it towed to dealer this morning.
Sadly Lemon Laws don't exist in Canada.Honestly this is unacceptable for a new truck. Really questioning Toyota reliability nowadays....
Keep a log of EVERYTHING. Start looking into lemon laws for your car.
