Goriders
2024 Tacoma Sport Plus
I got one with my truck as it was the only one available. Looked at a few others as well. I don’t regret it. Looks good. Easy to use. It’s pretty water tight. Every time it rained or I’ve been to the car wash I haven’t noticed any leaking.
Only downside is the tie-down rails move slightly down and in so when I bought the OEM cargo divider I had to trim a bit off each side.
Carlisle Pa.
24 Tacoma sport (underground)
End of August I've been waiting on my Taco sport for 6months here in Carlisle Pa. I'm getting this OEM cover but the dealership going to discount this cover for this long wait
Taco Golfer
Mark
Mt Pleasant SC
The OEM cover is the old MX4 design and better than the new MX4 design. I briefly had the new MX4 and returned it because when you opened it after rain it pours water all over the contents of your bed. It no longer drops the accessory rail which is a serious bummer.
I just got the OEM cover and it is notably heavier than the new MX4. it is nice that the OEM cover still has the factory rail dropped and fully usable. The only benefits to the new MX4 is that it is much easier to remove if you need to take it off quickly.
Not sure I understand when you say the OEM “still has factory rail dropped and fully usable”. Can you elaborate? Thx
UT
OEM cover requires to remove the two side accessory rails and drop them down about an inch with an adapter that comes with the cover.
rem2582
Randall
Cleveland, TN
Tacoma TRD Sport 4x4
Just installed my OEM Toyota hard bed cover. Super high quality and easy to install. Looks great too, if anyone is on the fence call your Toyota dealer and order one.
I’m happy with mine too. I have the exact same bed cover.
Goriders
the hardware attaches to the bed rail attachment points. You reattach the bed rails after the tonneau hardware is secured.
But they end up moving in about 3/4” and down about the same amount.
Bluznvice
West
I bought mine weeks ago and probably won’t get my truck until August or September (if ever at this rate). But man that looks clean!
Anything funky on the install you can share?
Yeah...do NOT use an impact gun to reinstall the rail torx screws.
You might be fine 9 outta 10 times, but that one screw is gonna be a bitch to get out.
Bluznvice
West
Also...mine didn't come with instructions. Said to contact the dealer to get a copy. But, there's some videos about installing the Tundra cover that are almost exact.
There's also a sticker on the underside of the cover that shows how the mounting bolts are installed. Look at it before trying every possible variation.
2024 Tacoma Toyota OEM hard bed tonneau cover is NICE. IMG_20240615_195926915_HDR
UT
I made this mistake 😂
Bluznvice
West
Yeah...laying upside down in the bed, penis fingers fumbling with the parts, dropping them on my face, practicing my old navy vocabulary...finally getting it together then going "that ain't right". Take apart, repeat a couple times. Then the big blue sticker comes into focus. Aw shit. Nobody else there to call dumbass.
Tekoma
Michael
North Carolina
The installation instructions are posted on this form and I just reposted them a few post back
Tacoman66
Edwardsville, IL
2024 Toyota Tacoma Limited
I had mine installed at the dealer prior to delivery. It is a very clean look. However, it is definitely not waterproof. I get water in the bed both going through a car wash and when it rains. Trying to figure out how the water gets n when it rains.
diablo2112
Southwest USA
The only flaw with the otherwise excellent OEM cover is the attachment hardware. It's hard to install, and you'll drop washers more than once. Given this is supposed to be easy to remove/replace, the hardware is a bit of a fail. They should have used captured bolts on the cover with the correct spacers, and handwheel nuts underneath to make it removable without tools.
