gofastdan
I gladly paid the $10 for a month's access to be able to shut up the seatbelt chime and make other assorted changes. Compare that to going to the dealer and begging them to help you out. Good luck.anything like this that doesn't have a subscription?
I did spring for a more expensive OBD reader though. The Carista unit is fairly limited in the software that it works with, as in it basically only plays well with the Carista app. That is fine if you only want to make changes to vehicles that Carista supports but in my case I also want to be able to make changes to my BMW motorcycle, which requires an app called Motoscan. Motoscan and the Carista hardware don't support each other. I ended up buying an OBDLink LX. Yup, it's even more expensive than the Carista unit but it works with almost any app, so I can use Carista to make changes to the Toyota and Motoscan for my BMW, etc... You can get cheaper units but most of them aren't using genuine chipsets and may or may not work with the different apps. You could try this one that claims to work with the Carista app and return it if it doesn't work.
To your point though, there are lots of apps that read codes and whatnot but I haven't found anything that allows you to make permanent changes for free, although some apps sell permanent access. Those apps charge something like $15 for each vehicle model they support though, which could get really expensive if you have multiple autos to tinker with. I think Carista's pricing is more than fair.
